wheel
Not from Estonia? Don't speak Estonian? Post here - due the spam registration IS needed
alexis
wheel
Postitus Postitas alexis »
?????? 155R15 (Beetle 1966)
3
2
2
1
1
Re: wheel
"Nemetskimi bukvami" (i estonskimi oshibkami :) ):
Iz Estonii ne naidjosh. Ja tolko-shto ishel.
Bõstrõi i deshevlii variant - stavish na zad 185/65, kotorogo mozhno naiti. Polutshjajetsa "potshti pravilnõi diameter".
Idealnõi (i €€€) variant - zakazat katshestvennõje rezinõ pravilogo razmera. Stojat 150+€ / stuk. Skolko vremeni zaimjot, neizvestno...
Eshjo variant zakazat s neizvestnogo proizvoditelja. Naverno 60€ / stuk. Naverno i vremeni zaimjot.
Tak kak ja svoi zuk tolko poprobovat hotel, võbiral pervõi variant. Na drugoi zuk (kotorom i nemnozko ezdit budu. Gdeto 2020+), poidut katshestvennõje - shtob tsherez paru goda opjat novõh ne ishel :)
Jesli eshjo variantov jest, to blagadaril bõ, jesli iz nih slõshel!
PS! Na kartinke vidno tshastlivoe neudatsha ( ja nadejus)!
Viimati muutis Teet, T Juul 30, 2019 11:20 am, muudetud 1 kord kokku.
Re: wheel
185/65 is closest available.
Tire Size Comparison
Spec. Sidewall Radius Diameter Circumference Revs/km Difference
155/80-15 124mm 314mm 629mm 1976mm 506 0.0%
185/65-15 120mm 311mm 622mm 1952mm 512 -1.2%
175/65-15 114mm 304mm 608mm 1912mm 523 -3.3%
165/65-15 107mm 298mm 596mm 1871mm 535 -5.3%
https://www.miata.net/garage/tirecalc.html" onclick="window.open(this.href);return false;
https://fs.ee/rehvid/?e-summer=1&e-widt ... &e-search=" onclick="window.open(this.href);return false;
alexis
Re: wheel
??????? ?????????? 165 80 R15 - ????? ????? ?!
Re: wheel
i have used 165/80-15 on my 1971 model 1302 also.
if no cracs on sides and you do not drive too fast, then old tires are also ok.
alexis
Re: wheel
Tere! Tere!
???? 155R15 ...
???? 155R15 ...
????? 165R15 !!!
????? 165R15 !!!
????? 165R15 !!!
????? 165R15 !!!
