- töötab koos suvalise süütusepooliga mis on 1.5oomi või enam
- kontaktivaba
- instruktsiooniga
- hoidik ja juhtmed POLE KAUBA SEES
hind: 120eur
kontakt: Valdis, +37129492009, ozvalds@inbox.lv
For more info, tech specification, the data here --
http://www.machine7.com/section.php?xSec=1539 http://www.machine7.com/section.php?xSec=1539
"The Distributor housing is CNC machined from 6061 T-6 alloy aluminum and is polished to a beautiful finish. These distributors are adjustable utilizing a GM Delco Style advance mechanism. "The Distributor housing is CNC machined from 6061 T-6 alloy aluminum and is polished to a beautiful finish. These distributors are adjustable utilizing a GM Delco Style advance mechanism.
The housing and deck are CNC machined holding a tolerance of +0.000 to +0.003 of an inch. The housing and deck are CNC machined holding a tolerance of +0000 to +0003 of an inch.
Tempered .500 inch shaft has low torsion displacement for more accurate timing and longevity Tempered .500 inch shaft has low Torsion displacement for more accurate timing and Longevity
A top roller bearing and lower self lubricating oil impregnated bronze sintered bushing which reduces friction and high RPM vibrations. A top roller bearing and lower self Lubricating oil impregnated bronze sintered bushing Which reduces friction and high RPM vibrations. Additional spring sets are included for custom curving. Additional spring sets are included for custom curving. Easy to use proprietary mechanical advance adjustment feature allows for easy advance limiting Easy to use proprietary mechanical advance adjustment feature Allow for easy advance limiting
Compatible with capacitive discharge systems Compatible with capacitive discharge systems
High quality cap utilize brass - Male Style - terminals for excellent conductivity " High quality cap process, used brass - Male Style - terminals for excellent conductivity "
